Saltar al contenido principal
No boot up, no display, no beeps though
So first things first, 0 display. My screen was broken a while back, was hooked up to my tv anyhow so I never bothered fixing it, though: when attempting to start up, no sounds. No display. Everything turns on but nothing else. All opticals, screen lights up (all it does) but no external display will work. I've cycled between my living room tv, my desktop monitor, and my bedroom tv and nada. Could it not be waking from sleep mode? I'm mostly clueless with laptops, used to working with desktops. TIA
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
It could be a problem with static discharge, if so do the following.
1. Disconnect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds, then release for 30 sec and then hold down for another 30sec
4. Plug in power; replace battery and power on laptop.
Hope this helps
Fue útil esta respuesta?
Puntuación 3
5 comentarios:
Still no dice, thanks though
- de
@paller try pulling the ram sticks one at a time . If one stick goes it stops the works so alternate the sticks
- de
You may also want to try a different cable
- de
Chip faulure, need to reball
- de
I'm having same issue ram works in different laptop and ssd but not bios beep and no display
- de
Añadir tu respuesta
K R estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 3,273
