Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
After Battery Replacement, My iPhone 6 Keeps Rebooting.
I accidentally mixed up the screws that secure the charging cover. I put them back in the right place, but now my phone reboots after about 3 min. Is there anything I can do?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
Turns out that the pins on the cable weren’t ligned up right.  They were just a little bit off, and that’s what was causing the issue.  We got them aligned right and everything worked.
Fue útil esta respuesta?
Puntuación 0
Before you mixed up the screws, the iPhone booted properly and worked for more than 3 minutes?
Puntuación 0
2 comentarios:
Yes, before the repair it worked normally. I also noticed, it doesn't reboot while in Airplane mode for some reason.
- de
The behavior of rebooting every 3 minutes is very odd. I dont believe (could be wrong) that mixing up those screws can do damage. If memory serves me right, the screws pass through the board and not directly onto where a longer screw would do damage.
- de
Before the repair, you mean with the original battery? My guess: the replacement battery is a bad one. Try another battery please.
Puntuación 0
1 comentario:
I put my origional battery back into my iPhone and even did a software restore, and it still reboots.
- de
This looks to be a general problem on iPhones whenever thys battery replacement..I’m facing the same challenge. my 6s+ keeps restarting over and over and charge percentage is stuck after replacing the battery… gosh! quite irritating
Puntuación 0
Añadir tu respuesta
Alex Hadfield estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,097
