Saltar al contenido principal
Guías y soporte para varias marcas y estilos de TV.
Preguntas 7163 Ver todo
TV will not turn on. No LED.
Panasonic TC-P50S30
I have replace the Power board, still nothing. I am getting 10 volts on P6 (it says 5v on the board), and I am getting 10 volts to the switch. Still it will not turn on. What next?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
The voltage is actually 5v (I didn't notice the doubler was switched on).
- de
Agregar un comentario
1 Respuesta
Have you tried checking the outlet?
Fue útil esta respuesta?
Puntuación 0
Comentarios:
If you are referring to the wall receptical, yes. There is also 120v at the connecter on the power board. There is also 5v at the standby pin on the main board. I can find no fault with the power board, and I have also replaced the board, still no start or standby led. I have just ordered another main board, and I'll keep you posted.
- de
Got another main board, and the tv powers up, but the picture is horrible. Brights are whited out, and the darks are blacked out.
- de
I sent that Main bd. back and got another one from another vendor. TV works fine and the picture is as outstanding as it ever was. Problem solved!
- de
Añadir tu respuesta
Al Burr estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 72
