Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 4095 Ver todo
lost a small connector, phone still works
My phone stopped charging so I replaced the whole charging port, but this small connector right above the loud speaker fell off its wire. The thing is my phone works like normal. I can charge it, wifi works, 4g works, speaker works.
I dont understand, what does that connector do? I tried adding a photo
https://gyazo.com/db200d81f3e0a517ea5cac...
edit: The connector im talking about has a red circle around it on the picture, the wire it used to sit on has a green circle
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Thanks, I tried called two people and had no problem with the signal, I guess its no a big problem then.
- de
How possible network connector is open and phone still get network
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
This is the main cellular antenna, right now your phone is on secondary antenna so it still appears to work, but expect significant 4G speed reduction and increased battery drain.
Fue útil esta respuesta?
Puntuación 3
REF: Reemplazar conector Lightning en un iPhone 5s
Look at Step 23. Are you referring to the antenna connector? Is it a round connector attached to a 1 inch long cable that pushes on top of its mating connector on the circuit board? I believe this is your primary/main antenna for cellular reception. Given that you have cellular reception, my guess the consequence for breaking this connector will be you won't have cellular reception is weaker signal areas where you used to have reception.
Puntuación 1
Hey!
Shortly: This is the cell-antenna and you need to connect it on the board at this little round connector.
Puntuación 1
Añadir tu respuesta
soeharebrentpådvd estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 43
