Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 1523 Ver todo
Short on PP_CPU, PP_GPU, and PP_SOC common failures?
Hello,
Long story short: water damaged iPhone 6s (daughter absolutely *had* to wait in line, in the rain, to ride Tower of Terror). After installing a new screen/digitizer assembly and sending it to a "microsoldering shop" (they took my money and did a half-assed job not fixing the phone), the phone powered on but drained battery in about an hour. Finally it got to the point where the phone would boot, but as soon as you entered the passcode it would hang. A forced-restart worked, but it would just hang again on the lock screen.
*sigh* Resisting the rant at this point... ;-)
So I bought an AmScope (thanks for the recommendation Jessa, I've been wanting an excuse to get a microscope for a long time) and took the phone apart. At least the repair shop claimed to have done an ultrasonic cleaning and the board was indeed very clean. The repair shop had identified about 8 caps around the PMIC (U2000) that were badly corroded and they said they "fixed them", and by "fixed" they apparently meant removed the caps but did not replace them.
I realize you can get away with pulling a few caps here and there, but 6 to 8 caps on the output of PP_GPU (or any LDO for that matter) is not a good idea. The camera LDO (U3200) was also badly corroded, and the input cap (U3210) to the LDO needed replacing as well. So I ordered the parts and started poking around while waiting for them to arrive.
So far I have found that PP_CPU, PP_GPU, and PP_SOC (BUCK0..2) are shorted. PP_VCC_MAIN is fine, as well as all the other outputs of the PMIC (BUCK3..8).
I was wondering if anyone has seen something like this and could say "oh yeah, we have seen that before and x% of the time it is the PMIC...", or similar?
I know removing the output inductors (L2000..2003, L2010..2013, and L2020..2021) would be the way to isolate and test the PMIC from the output filter caps, but I'm reluctant to remove them because they are right up next to the CPU and they appear rather fragile.
Any tips, suggestions, or insight would be greatly appreciated.
Thanks,
Matthew
Update (08/17/2017)
TL;DR - see "TL;DR start here" below:
Well, the *why* of it all is a slippery slope. I'm a geek by nature, and spent my childhood taking everything apart to see how it worked. I've been into programming and electronics since I was around 12, but being technically and mechanically inclined can get you into trouble sometimes. I have spent the greater part of my life always "doing/fixing it myself", which for me means doing tons or research about the task, seeing what others did, checking out procedures and tools, etc. This all takes a *lot* of time. Sometimes things go well, other times the results were not worth the effort. I basically invest a lot of time and money learning to do something *once*.
Always the biggest problem when I start a project I have never done before is that I don't have the experience of having done the job many times before. When you pay someone to do a job, you are not just paying for the time or materials (those aspects are usually the smallest part of the cost), you are paying for their expertise and experience of having done the job before and that they have the skill and knowledge to do the job right. I'm learning that sometimes paying someone is faster and easier than all the trouble of doing it yourself, especially if you are not set up to do the job.
Fixing iPhones is one of those things that I really did not want to get into. Becoming a repair shop is not on my todo list, and phones are expensive enough that I really don't like messing around inside them. Getting schematics and phone information is an exercise in visiting websites that make me nervous, the technical info is hard to get, and you never know if the information is accurate or reliable (or legal).
However, I have two daughters and thus have had my share of replacing phone screens and batteries; and I'm really thankful that iFixit exists to provide those parts at reasonable prices. I never had to deal with a water-damaged phone though, until now. So this time I decided I would pay the experts, but sadly it did not pay off. I did get an ultrasonic cleaning out of it (I think, I can't prove that though). I'm not willing to spend $500 for the entry-level cleaner that really does the job (according to Jessa and Louis). I already spent more than that on the microscope, but I wanted one of those for a long time, and the rest of the family likes to look at the mirco-world too. :-) So the microscope was worth the cost to add to my bench.
Wow, look at all that text... The older I get, the more I ramble. Finally getting to the topic at hand, i.e. the phone:
TL;DR - start here:
I did not replace any of the caps yet. I started testing for shorts first since the phone went from seeming to work, albeit draining the battery faster than normal, to locking up after booting. The repair shop also failed to replace the input cap on the U3200 LDO, and before the phone started locking-up my daughter pointed out that the camera and flash-LED were not working. After checking the schematics, oh look, the missing cap was on the input to the camera LDO...
Electronics joke:
Q: "What do you call an LDO with no input or output caps?"
A: "An oscillator."
Ok, that was bad. ;-) But it is true. Every LDO I have ever worked with states in the datasheet that the input and output caps are required, X5R or X7R, or the LDO will oscillate. It really added to my frustration to see the repair shop did not replace the U3200 LDO input cap.
I understand what the diode (beep) test is actually doing, so I also checked the actual resistance of the "shorted" paths, both ways (negative on the cap, then negative on ground):
PP_CPU: 33ohms, 88ohms
PP_GPU: 9.6ohms, 11.2ohms
PP_SOC: 9.6ohms, 11.2ohms
All the other outputs of the PMIC were 2.5K or more. Actually, none of those three above are complete shorts to ground, since in that case I would expect to read about 0.52ohms (which is what I get when I check the ground-side of the caps).
It is interesting if you consider the voltage and current rating for the output of something like PP_CPU, which is 1.03V @ 12.5A!! I realize that is a max rating, but let's just say the load is 10ohms (the resistance I'm seeing) @ 1.03V, the current would only be 103mA. So maybe I don't have any shorts after all? To draw even 2A @1.03V the load resistance during operation would have to drop to 0.515ohms...
This is the biggest problem I'm having with this repair, I don't have another known good iPhone 6s to open and compare to, or lots of experience fixing phones where I would know these values and be able to use experience and insight to guide me. So far I have not been able to find anyone who has made a list of "normal" values (voltages, resistance measurements, etc.) for the various phones. Does anyone know the normal resistance of the PP_CPU, PP_GPU, and PP_SOC nets?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
2 Respuestas
Solución Elegida
Sounds to me like you are more than capable fo doing this water damage repair yourself...why did you send it to a shop? No need to answer if you don't want to, I don't want to get you all riled up again ;>).
Have you replaced the missing caps? I agree, removing them is a bad idea. They are there to filter the PP_CPU line but more importantly to act as a reservoir of juice when the CPU makes instantaneous power demands. The PMIC can't respond fast enough due to the inherent inductance of the logic board copper traces. That's why there are lots of caps as close as possible to the power pins of any IC. The bigger the potential demand, the more caps are present. Removing 8 of them could cripple the CPU and may be causing the boot hang.
You are exactly correct in saying that removing the inductors on the CPU/GPU and SOC line is the only way to know for sure where the short is. And yes, they are fragile and break easily when trying to remove them. If you haven't done those yet, I would practice on a few dead boards first. Of course, you could just order some new ones so that you can scrape the old one off the board :>)
However, I'll back up here just a step...what are those lines measuring in resistance mode? Lot's of folks get taken on a wild ride by assuming CPU/GPU and SOC are shorted because they hear their meter "beep". The reality is that those lines are low resistance, anywhere from 20 Ohms to 100 Ohms. Most meters will "beep" below 50 Ohms and some even as high as 100 Ohms. So unless you are measuring less than a few Ohms, it probably isn't a short. The fact that your phone does boot, at least partially, leads me to believe that there isn't a true short. No offense intended, I just need to be certain.
What about the other outputs of the PMIC; are any other secondary lines shorted? That could help point towards a major failure of the PMIC. If everything else looks good then your options are to remove the PMIC (yuck, the 6S it is smothered in underfill) or remove the inductors.
Bottom line is that if you truly have a short under in the CPU (a real possibility with water damage), that phone is dead. If you're really advanced you could try to reball the CPU/SDRAM.
Fue útil esta respuesta?
Calificación 4
Comentarios:
Hi Matthew. It helps keep things tidy here if you comment on an answer rather than adding answers to your own question. There is a character limit on comments though so the trick is to split it up.
At any rate, your readings on the three rails seem correct to me. As you know, checking the resistance of a dynamic rail like PP_CPU is not like checking the resistance of a passive line. The PP_CPU rail is rated at 12.5A on the schematic but Ohm's Law does not reconcile that with the measured resistance. However, measuring a line like PP_CPU is like looking at the inside of the CPU itself. It has billions of transistors and depending on how many of them are switched on or off is what impacts the current draw when it is running.
por
(see I was character limited too!)
At this point, I would replace the missing capacitors and then start probing. The PMIC also has some LDO lines (VLDO1 - VLDO13) in addition to the Buck Converters. There is also a PMU on the baseband side (U_PMICRF). Ultimately, the phone is doing a partial boot. What that tells me is that something is failing as the CPU checks all of the subsystems. That's where the problem lies. You either have a failed Buck/LDO or a subsystem that is bringing one of the PMIC's into current limiting.
That said, not all water damage devices can be saved.
por
Apologizes, I'm used to a more traditional forum with thread topics that simply contain posts. I'm not sure what to think of these new style lists. It seems to be more like a game with people focused on their rep. I hope it is effective.
Thanks for the additional info. Just to be clear, are you confirming that the 10-ish ohms that I'm seeing on the static measurement of PP_CPU, PP_GPU, and PP_SOC are what you have seen before and/or would expect for static measurements of those lines? If that is the case, then that would be very comforting and I will go ahead and finish the repair as you suggested.
I did not notice the additional LDO lines coming from the PMIC, thanks for pointing that out. I will check those too. The schematics I have indicate that the max rating for PP_CPU is 12.5A. That really surprised me, and the value you cited (7.6A) seems more reasonable (but still really crazy when you think about that this is a small mobile device powered from a battery!)
por
cont...
The differing values between your schematics and mine are worrying to me. I hope the schematics as a whole are not flawed. I wish there was a place to buy valid schematics, personally I would certainly be happy to pay a fair price for them.
por
Yeah, my bad. The iPhone 6 has the 7.6A rating whereas the iPhone 6S has 12.5A. I'll correct my comment. Don't forget that the GPU can sink up to 10.5A and the SOC 4.7A. Pretty awesome for a handheld device!! The resistance values are similar to what I have seen so I would move on to the replacement of the caps.
As for the non-threaded format, this is more like StackExchange. It's focussed on getting the best answer possible, not a long discussion thread. Rep helps the best answers flow to the top of the heap instead of being hidden within the weeds. Some folks focus on the points but in reality, few people vote or select answers so you have to be a bit of a masochist to contribute here ;>).
por
Mostrar 6 comentarios más
partial boot, keep booting?
1. check tristar if bad replace it,
bad tristar can make iphone boot looping or can turn on in a while then suddnly pwr off or rebotp
2. check nand voltage output, ......
3. check sdram v output.......
pp gpu cpu has nature low res
u can compare to good board before judge thats was a shorted
u can buy
wu xin ji dongle ma fren that a lot helping too, i knew zxw is good
hope this helps
Calificación 1
Añadir tu respuesta
matthew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 68
Últimos 30 Días: 296
Todo El Tiempo: 2,660
