Saltar al contenido principal
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
Preguntas 35 Ver todo
Boot failure, sudden restarts, glitchy screen, and unresponsiveness.
So the other day, I left Ndless on my calculator too long, and I took it out to find that there was a glitched screen left on all night.
Calculator Info:
  • TI-Nspire CX CAS
  • OS 4.4.0.532
  • Had Ndless installed (4.4.0 r2007)
  • Hardware revision O (0?)
  • Was using nPDF
Current Symptoms:
  • Sudden restarts
  • Glitchy screen (Usually during restarts)
  • Does not respond to resets when reset button is pressed
    • Restarts when disconnected from computer (Battery?)
What I've done so far:
  • Reinstall OS.
  • Delete, then reinstall OS.
  • Take out and put back same battery.
I would give images, but due to the buggy nature of this problem, it simply won't cooperate.
Update (8/16/17): Today my TI-Nspire CX CAS gave me a glitched TI-Nspire Classic boot. Of course, it glitched, but still, it was something.
Edit (11/20/17): My calculator doesn't turn on anymore. Help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Hmm, that's an interesting problem! I haven't seen that before, but my best guess is that you heat damaged the board.
Try taking it apart and see if anything is amiss.
Reemplazo de conector de alimentación de la Texas Instruments TI-Nspire CX
You may need to get a new main board. Perhaps you can find a donor unit with a cracked screen.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Actually, the problem only started after a jailbreak software was installed too long, it would be a strange coincidence if it were the heat.
- de
Look at this ;)
https://tiplanet.org/modules/archives/do...
Puntuación 0
Añadir tu respuesta
TruDev estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,030
