HELP: why are my breaks not working?!
I have an Audi a6, year 2000. My breaks were locking up every now and then and my break pedal was super tight. I did some research and found that i had to replace my abs sensors. I did that and now my breaks are acting the total opposite. My break pedal goes all the way to the floor and it is hard to stop my car. I tried to bleed the breaks but only two of them actually bleed.
could this be a blockage issue?
if so i feel like the blockage would cause my breaks to be hard such as too much pressure...
could it maybe be the master cylinders?
or did i just mess up my abs somehow?
Es esta una buena pregunta?
Did you replace your wheel speed sensors or your ABS module?
Speed sensors are in no way related to the hydraulics of your brakes. If you replaced your ABS module/hydraulic unit then the brakes will need to be bled through.
Are you unable to open the other two bleeders or does no fluid come out? It's possible that the bleed hole is plugged up of the rubber caps were missing.
- Por Troy Mac1ure
I have same problema, from no whear my barake just broke. I already have change abs modulator, esp control module and check al wire, fuse and relay. But then start bleeding my rear left and front right wheel no bleed
- Por Tomas
