Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1672 Ver todo
When home button is clicked Once it does 6-7 rapid clicks
Hello I have a customer with an iPhone 7. I replaced the screen and the home button is odd. I click it once and the home button gives me about 6-7 rapid clicks. Is it the home button pressure sensor? How can I fix this.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Hey!
Try to disconnect the Home-Botton connector from the flex cable behind the LCD assembly, remove the Button completely and resest all parts again. Then test it again.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Tried that still having same issue.
- de
Okay, in this case - if you are really sure all is sitting in place and is connected correctly - it could be possible the flex cable or button itself was killed. I rememvered the button and its board sticks very hard at the back of the LCD assembly and needs to remove carefully. Maybe you detect any damages at the board or cable?
And I think you should try another home button-flex.
- de
Añadir tu respuesta
Hunter Kegher estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 653
