Saltar al contenido principal
Guías de reparación y soporte para teléfonos fabricados por Oppo Electronics Corp.
Preguntas 200 Ver todo
Touch screen not respond
The touch screen works only in the recovery mode
I have done hard reset and still the problem !!?????
Es esta una buena pregunta?
Puntuación 8
6 comentarios
My phone touch screen is working but display is not working what the problem with my phone
- de
मेरे फोन का टच नहीं काम कर रहा है
- de
My screen isn’t working at all but all bottons on the side are all workin
- de
Oppo r831k touch not working
- de
I'm using Oppo Reno 2z screen not responding
- de
Mostrar 1 comentario más
Agregar un comentario
1 Respuesta
Solución Elegida
If I'm not mistaken you navigate with the volume buttons and the power button in recovery mode so you don't use the touch screen . So the digitizer is not working so as you did not specify which oppo phone you have I canot direct you to a digitizer but you can find them on ebay or amazon . Oppo Phone Repair
This guide page will show screen replacement for 3 different oppo phones . Hope this helps
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
I have oppo a37
My problem is there is no responding from touch screen at all ,so I tried to fix the problem with hard reset but it not help
When I was trying to do the hard reset i see touch screen Respond well but only in the recovery mode ,after reboot the phone to normal mode still the problem no responding from touch screen .
- de
hi I am currently using f1s screen can’t be touch no response what will I do?
- de
jimfixerir i just replace the lcd with frame the led lights lighten up the back buttons lighten but the screen doesnt work, it is still black but it rings there is a soundwhat might be the problem? for oppo f1s
- de
ओप्पो a3s का टच नहीं काम कर रहा है
- de
Añadir tu respuesta
Haval estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 59
Ultimos 30 días: 351
Todo El Tiempo: 41,542
