Battery problem in Braun electric toothbrush 3D D 15511
Can this can be repaired
Es esta una buena pregunta?
In theory yes, in practice...that depends. I have a similar model that failed and I opened it up to see if I could just replace the battery, The problem was everything was corroded to near death inside. The battery is not designed for easy replacement and everything is soldered in place. I found the defective components and was able to order them (IC's & Battery) but the logic board was in very bad shape.
So I would certainly try, otherwise the tooth brush will just end up in the trash. Hopefully you'll have better luck than I did.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 117
