Saltar al contenido principal
El Acer Aspire Switch 10 SW5-011-18R3 es una tableta 2 en 1 con teclado acoplable que ejecuta el sistema operativo Windows. Fue lanzado originalmente en mayo de 2014.
Preguntas 13 Ver todo
My power light is on and it wont turn on
i can only charge it by the secandary port now the light is sometimes blue or orange when i try to turn on it wont but some times i can see the montior flash and then nothing it has done this for a long time and i dont want to send it in
Update (08/08/2017)
my pin hole is on top insted of where you said it was between the micro sd and headphones still i probed the pinhole and could not feela switch for reset
Es esta una buena pregunta?
Puntuación 1
1 comentario
I have the same problem Help me
- de
Agregar un comentario
3 Respuestas
Solución Elegida
If the device has a charge, the indicator light on the power button displays a steady blue or amber color when plugged in, and still will not turn it needs to be reset. There is a reset pinhole between the microphone and Micro SD card slot on the right side of the device (screen facing you in upright position). Insert a pin needle size object into the pinhole and hold down the reset button for four seconds. Device should turn on.Hope this helps
Fue útil esta respuesta?
Puntuación 1
The above I think will assist for basic reset but mine like the original posters, has a light but no amount of poking the hole resets the devise . Mine wont power on after a acer bios update which appears to have killed the devise. Very poor support on these firmware updates.
Puntuación 0
My Acer in aspire one have the same problem…orange light but cant boot up..i just don't know what to do..
Puntuación 0
Añadir tu respuesta
william estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 7,410
