Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
Preguntas 343 Ver todo
Screen appears to have soft wrinkles after replacing camera
I bought an iPad that needed a new rear facing camera.
I CAREFULLY opened the iPad, disconnected the battery, found the defective camera, replaced it, reconnected the power supply, and now the screen appears to have soft, undulating wrinkles on the upper half.
Looking for any answers!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
3 Respuestas
Solución Elegida
Hi and thanks so much for your response.
The initial problem with the iPad was a bad rear camera, which is why I opened it. I used playing cards to pry the digitizer off and might've accidentally dug a little too deep between the digitizer and LCD. Pulled out two small pieces of 'wire fabric' looking stuff from one edge of the joint between the digitizer and LCD. I never even detached the connector or took off the cover plate.
Fue útil esta respuesta?
Puntuación 0
That sounds like it might be a loose connection or damage on the display cable. I would attempt to reseat the display cable and try again. When you reseat the display cable, don't put the iPad all the way back together before testing to avoid needlessly replacing the adhesive multiple times.
Puntuación 0
Try not to tighten the four lcd screws to much, if the problem still remains try applying a little heat from a save distance. This could help retract the wrinkles.
Puntuación 0
Añadir tu respuesta
Craig Sweeny estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 367
