iMac Hard Drive upgrade
Would any Western Digital Hard Drive- Model: WD10EALX-408EA0 work in a 2011 iMac without fan issues?
Same drive as in the 27" iMac 2012 [EMC 2546]
Es esta una buena pregunta?
It makes no difference who's drive you use in the 2011 models onwards (3.5" drive'd systems)
All of them need a means to see the thermal load of the drive so the systems cooling system is able to adjust to it.
Apple over the years has used a few different ways of getting that needed input by either applying a thermal sensor on the external can of the drive, leveraging the burn-in sensor the HD makers started putting into the drives, and lastly then getting them to allow Apple access to them via custom firmware.
The good news is there is a way to intercept the SMC signal with this: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade which allows you to put in any 3.5" drive or even a 2.5" SSD drive! This is the best method of controlling the systems cooling while some people have tried using software over the years we have found the in-line sensor is better in protecting the system and allowing the system to run quietly when there is no load.
Consider getting a SSHD drive to get some better performance and if you can swing it add in a second drive in this case a SSD. I strongly recommend the dual drive config if you want the best performance! Heres the guides for both:
Guía
Dificultad:
Moderado
20 - 30 minutes
Guía
Dificultad:
Difícil
1 - 3 hours
Fue útil esta respuesta?
Thanks, so even if the new drive came out of a 2012 iMac the OWC temperature sensor would still be needed?
Things get a bit muddled here as the 27" models from 2012 use 3.5" HD drives and yes they all need the in-line thermal sensor. OWC makes a slightly different version for the 2012 onwards models.
On the other hand... The 21.5" models from 2012 onwards use the smaller 2.5" HD and use a different method SMART.
As far as using a drive that came out of a 2012 system. Can't tell you what you'll encounter as I've never tried stealing from a newer system to put into a 2011 model (3.5" drive). On the surface I would think it would work. As the Apple logo'ed drive would have the altered design. If the drive doesn't have the Apple logo on it its not the original drive.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 363
2 comentarios
Drive specs & info: Western Digital Caviar Blue 1TB Review (WD10EALX)
- de Dan
You may want to go with a newer better drive like: Seagate FireCuda SSHD
- de Dan
