Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Laptop de 14.1" con procesador Intel Core 2 Duo T5450 de Acer
Can I replace my LCD screen or repair it?
The outer part of the screen is intact but the inside is cracked. Also before this happened my screen used to flicker and when I need to reinstall windows I can't see what I am doing.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
Faian Jamil, if your LCD is cracked I believe that you will definely have to replace it. As for the issues that you had prior to this, it could be a bad inverter a bad backlight and/or bad cable. You will have to reasses this when you have a known goodworking screen. The LCD is available here http://www.blisscomputers.net/acer-exten... and multiple other places. Good luck.
Fue útil esta respuesta?
Puntuación 2
If the screen is cracked, you cannot repair it. The screen has to be replaced and it's easy to do.
All you have to do, is remove the screen bezel and disconnect the screen.
Imagen
The following guide explains how to fix broken hinges but you can use it for replacing the screen too.
http://www.insidemylaptop.com/replace-br...
Puntuación 0
They best way would be to replace the screen by using a service manual or online tutorials. You can order new screen online using Amazon or eBay.
Puntuación 0
Yes, this is very easy to do. You can find instructions how to replace a laptop screen and both glossy Acer Extensa 4620 screen and matte Acer Extensa 4620 LCD display on NotebookScreen.eu
Puntuación 0
Añadir tu respuesta
[deleted] estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 2,967
