Saltar al contenido principal
Un ordenador personal que reside en una ubicación con sus componentes principales dentro de una caja separada de los periféricos de terceros necesarios para la operación, como un ratón, teclado y monitor.
Preguntas 542 Ver todo
I lost files when I do my pc factory reset how can find them?
After factory reset I didnt find my files
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Stop using the computer, turn it off. Take it to a computer shop so they can use recovery software to get whatever is left..
If your data you lost is important there is no simple way to get it back. Software recovery is never 100%
Fue útil esta respuesta?
Puntuación 2
@yohannes61 what type of files? It is possible that they got overwritten when you performed the factory reset. You need to tell us what OS you are using and what type of files you are looking for. Also tell us what you have tried to recover those files.
Puntuación 2
If you did a factory reset stop using the computer and pull the hard drive . Place it in an external enclosure or use some other method of connecting it. Connect to another computer and us a program called Zar X then run a drive recovery . You will end up with a lot of raw data but you will be able to recover what hasn't already been overwritten . You will require a large amount of storage as you will be recovering as much data as was originally on the drive including things you deleted in the past that weren't overwritten . hope this helps
Puntuación 1
Try with Recuva free software, it worked to me a couple times when i had to find an erased file, are the same guys who use CCleaner to fix registry issues on windows, also cleans innecessary files, freeing lots of space. https://www.piriform.com/recuva
Puntuación 0
Añadir tu respuesta
Tekeste estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 67
