El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3787 Ver todo
Why new battery does not last even 5 hours?
I bought a new iphone 5s battery, after replacement, the battery still only last ~5 hours with normal usage, which is same with my 2 year old battery?
Seriously, I dont recommend to any people to buy if the quality is so poor!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
What was the source of your replacement battery?
por
Is the logic board getting hot? If so, it could be causing the battery to drain, new or old!
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
1 Respuesta
Solución Elegida
Did you check if the battery health was bad from the old battery before replacing it?
If the battery life was reported around 80% or higher using the Battery Life app on iOS, CoconutBattery on a MAC or 3Utools windows application on a PC then the battery is probably fine and the battery drain is caused by the system software on the phone.
A lot of times when the battery health is good a restore of the iPhone fixes the problem most of the time. Make sure you do a backup of the iPhone via iTunes before restoring it so you do not lose the data on the phone and can restore from a saved iTunes backup.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Haowei Qin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 101
