No bootable device available
It says to insert disc and press a key it says
Es esta una buena pregunta?
Hi @mmm813 , proceed to your acer bios, and check if the hard drive is detected.
Under the BIOS you should see if the HDD is detect,
If so, run HDD diagnostic test to check on your HDD.
Some BIOS has a built in simple HDD test, you can check from there.
else, your HDD could be faulty. the only way to test is to get a known working one to replace and see if the system detects it.
If your hdd has issues and wish to replace, I would recommend you to replace to a SSD for performance.
Fue útil esta respuesta?
try but i didnot work
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,300
