Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4256 Ver todo
Wi-Fi Weak and Dropping Signal
I'm having issues with my iPhone 6. I'm relatively tech savvy so I've tried to trouble shoot this as best as I could. I went through all the standard network setting resets and restores with no effect. Here's what's happening:
The wifi signal is often weak but it's worse than that. The phone will constantly drop and reconnect to networks as well as cycle through different signal strengths. Other times no networks will appear at all and when my network finally reappears it won't be able to connect. It only really works best with a direct line of sight to the router but even then there's no guarantees. I had thought this was an antenna issue so I took it into a local repair shop and had the antenna replaced but there's been literally no change. I'm curios if they actually replaced the antenna or what.
The worst part about all of this is that the phone will be mostly fine for a little while and then randomly the signal will start to drop until its gone altogether. I spend so much of my time looking to connect to connections that I know are there but my phone can't see or connect to.
So my final question is. Is this likely an antenna issue or is there possibly an issue with the wifi chip itself. I haven't been able to find anywhere what the symptoms of a faulty chip might be so I'm not sure. What's my best option at this point?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
The common culprit is the L shaped antennae cable that is used for 2.4 / 5.0 GHz WiFi.
Also the antenna with the 6ish screws located at top left of phone inside.
Fue útil esta respuesta?
Calificación 3
Hey
I know is crazy but try it and you will see the difference switch off ur iphone and put it on small frizz bad and leave it on the fridge for 3 hours then tacke it out dry it and plug it on
Second you need to change battery because the iphone come hot when you start to loose the signal i hope the first one will help with ur iPhone otherwise try the second
Good luck
Calificación 0
Añadir tu respuesta
jmeush estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 20
Todo El Tiempo: 164
