My charger will not fit into the port. How can I fix the charging port
The chargers will not go in. I think the charging port needs repair. How can this be done on LG Optimus L90
Es esta una buena pregunta?
Is the port bent? Are one of the prongs inside the port popped up? If either one of those is a yes. then you need to replace the port on the actual phone. If none of those is thne problem. Try getting a new charger and see if that works. Or try putting it in on an angle.
Goodluck!
-JR
Fue útil esta respuesta?
Yes the problem is the prongs are messed up. I tried with different chargers but nothing seems to work. Can you show me how to replace the charging port?
Thanks
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 58
Thanks
- de Abhi Shah
