Saltar al contenido principal
Ordered Verizon specific charge port, phone will not recognize
Ordered G5 battery port specific to phone.
Phone give message: "the module you've attached doesn't work with this phone or isn't inserted correctly. Please use a Verizon-compatible module..."
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Where did you order from?
These things are easily mixed up.
I suggest speaking with the seller to get a return or exchange.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I bought a charging port assembly from iFixit and got the same message.
- de
I bought a charging port from a different supplier, installed it and got this message. Put the original back it - works.
Update (07/07/2020)
It was most definitely a bad part, FYI! Problem solved with a charging port bought from a different supplier.
I had tried 2 different ones from same supplier and had same issue. They must’ve had a bad batch.
A good reminder to think about the parts you’re using, it could always be that!
Puntuación 0
Añadir tu respuesta
vanceakins75 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 400
