Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2531 Ver todo
Is my phone still fixable?
my phone dropped and it has black circles on the screen surface (that get larger when even the smallest amount of pressure is applied) , cracks all over, touch id no longer works and greyish colored lines down the phone.. the phone moves by itself and when you try to click something it clicks something else.. the screen looks like its about to fall off. is it still fixable or do i need to just get a whole new phone?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
This is fixable. You need a new screen assembly and possibly a home button. The screen LCD is damaged. When you put in a new screen, this will fix the touch issues and black spots as well as the cracks. If your home button still work when pressed, I don't recommend changing as you cannot reprogram a new Touch ID button at this time. Here is a link to purchase the parts and tools:
Reemplazo de pantalla de iPhone 6s
Remplazo Modulo del Botón Home del iPhone 6s
If you are not able to do the repair yourself, I would recommend using a local repair shop.
Imagen de iPhone 6s Ensamblaje del botón de inicio
Guía
Dificultad:
Moderado
25 - 40 minutes
Imagen de iPhone 6s Pantalla
Guía
Dificultad:
Moderado
30 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 3
Comentarios:
thank you so much.. i will bring it to the repair shop :)))
- de
You're welcome. Have a wonderful day!
- de
Añadir tu respuesta
Shanaya estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 629
