Saltar al contenido principal
Portátiles fabricadas por Dynabook (anteriormente Toshiba). Desde entonces, Toshiba transfirió el 100% de la propiedad del negocio de computadoras portátiles a Sharp.
Preguntas 1270 Ver todo
Toshiba Satellite c55-a wont boot
Hi, my toshiba laptop will not turn on. Prior to it not turning on it began to take a while to boot up, (from a black screen to the toshiba loading screen), but now it just stays on a black screen. I have tried a hard power cycle, and the power light on the laptop does light up with turned on with battery or ac adapter, along with the charging light. Thanks for any replies
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
It turns on and goes thru the Toshiba welcome, enter my pin and screen goes dark and will not loan windows 10
- de
Agregar un comentario
2 Respuestas
Does the laptop seem to be powering on the disk drive and the fans? Try connecting to an external monitor, if the external monitor is black or does not see a video signal, then the problem could be a defective graphics adapter which is generally built into the system board. If the external monitor works then the problem is a defective display or the back light has failed.
Fue útil esta respuesta?
Puntuación 0
maybe if you chick your laptop memory it is good idea.
clean it or replace it .
Puntuación 0
Añadir tu respuesta
Anthony Cahleizza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,577
