Saltar al contenido principal
Procesador Core 2 Duo modelo A1225 / mediados de 2007 y principios de 2008 / 2.4, 2.8 o 3.06 GHz
Preguntas 432 Ver todo
There is a video showing power supply replacement but no guide
I noticed on YouTube there is a video showing the replacement of the power supply, but no guide. I figure I'll use the HD replacement guide to get into the case, then refer to the video to replace it. Just a thought. If I get my act together before I replace the ps, I may create a "you can also replace" guide hooking off the HD replacement.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Looks like this machine could use several guides. Use the front bezel guide as a prerequisite.
LED de diagnóstico del iMac Intel 24" EMC 2134 y 2211
Next do the display as a guide. Then you can go to the logic board, then the power supply. It may also need one for the inverter, CPU and GPU replacement and upgrades.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Sheldon Carpenter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 66
