Repair and disassembly guides for the Jura Capresso IMPRESSA J5 coffee maker.
Preguntas 10 Ver todo
Jura J5 Won't dispense coffee or water , but runs
My Jura J5 does not dispense coffee or water, but runs. It collects in the tray instead. What can I do to fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
4 Respuestas
Hi there,
It sounds like the water lines are blocked with calcium. Have you descaled the machine?
Fue útil esta respuesta?
Calificación 0
The drain valve needs to be rebuilt. I had the same problem with my Jura. I disassembled it and rebuilt the drain value and brew group. It is back up and running after replacing the o-rings and regreasing the parts.
Calificación 0
Your drain valve is failing, allowing coffee to drain to the pan. It's a common problem. Either the seals are bad, or the steel plunger rod's plastic cap has unseated. Buy a rebuild kit for the drain valve, and consider gluing the cap on.
Calificación 0
Is there a shop other then Jura that can fix this same issue for me? Jura wants way to much money.
Calificación 0
Comentarios:
Please let me know if you were able to repair you machine?
por
Yes, there are others that will do this repair besides Jura. One that I know of is Parts Guru in PA. Just do a Google search. They've done a lot of the repair videos on Youtube on how to fix problems with the Jura. Tell them you have a drain value that needs to be rebuilt.
por
Añadir tu respuesta
Diana Abbasy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 23
Últimos 30 Días: 116
Todo El Tiempo: 950
