El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3634 Ver todo
iPhone goes to DFU Mode/Black screen every long period of time!
My iphone is stuck on black screen (DFU Mode) and Pressing Home and Lock button does not work,and it come backs to the DFU Mode It's really DFU mode detected by 3UTools,also tried other softwares and it's not recovery mode! and restoring it says Error restore 4014 then 3utools says it's invalid serial number.
After 2 days it ran out battery and then i tried to restore it and it works again,
And after 1 Weeks or sometimes it lasts months it goes to black screen/dfu mode again,
In short,I HAVE ALWAYS TO RESTORE EVERY LONG PERIOD OF TIME,
It's absolutely UNUSABLE because i always have to start all over again the progress on my iPhone!
I Also replaced the battery 2 TIMES,Replaced the screen too! and still getting this problem!!!
I also tried changing usb cable,tried another PC also tried MAC,AND EVERYTHING SOFTWARE SOLUTIONS THAT I SEE AND ALL OF THEM DIDN'T HELPED AND STILL GETTING THE PROBLEM!!
PLEASE HELP!!! i'm buying new iPhone in september but this iPhone is very special to me! Please tell me what hardware error is this!!,it auto boots to DFU Mode and it's very grueling because it prevents the iPhone to enter Any modes and it needs to be drained to make it able to enter recovery mode! For now the iPhone is broken again,PLEASE HELP ANYONE! I WOULD THANK YOU A MILLION FOR THE SOLUTION!!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
This sounds like what's going on with my phone. I have found that once it's running again as a newly setup phone it stays on unless nothing is running. I've had a white noise generator running since Friday and it hasn't crashed again yet. For me it seems safari related. My next thing is to try a new iCloud account and never use safari. That way no safari data comes over from my existing account. I'll post about it if it works.
por
Did the same situation happen after you flash your iPhone?
por
For me the situation continued even after being reset to factory settings at the Apple Store. Though, mine doesn't require the battery to drain. It just has to sit quietly for hours.
por
Agregar un comentario
2 Respuestas
Solución Elegida
No idea why some 5s does this probably liquid damage under baseband chip.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Looked it up and called for my imei. And it work. Could it still be that? Thanks!
por
99% it is the nand on the motherboard. 4014 leads to nand and if you remove the nand from a board and try to restore in 3u it will say invalid serial number as it cannot read it.
Calificación 2
Añadir tu respuesta
Yoshi Bash estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 19
Últimos 30 Días: 89
Todo El Tiempo: 986
