Saltar al contenido principal
Nintendo Switch es una videoconsola portátil a la que se puede jugar en el televisor a través de una estación de acoplamiento, o sobre la marcha. Sale a la venta el 3 de marzo de 2017.
Preguntas 704 Ver todo
Consoles no longer turning on after swapping internal memory
Hello there,
i have 2 consoles here with me, one of which has a cracked LCD and another that has a parental lock on it. out of curiosity i decided to swap the internal memory chips around to see if the parental lock was bound to the memory chip or one of the other boards. before removing the memory i made sure to disconnect the battery. once everything was all set up and ready to go i tried to turn them back on again to no prevail unfortunately.
any ideas or suggestions to help me here?
thanks!
Es esta una buena pregunta?
Puntuación 1
5 comentarios
slight update, i swapped the memory chips back, the one with the parental lock turns on again but the one with the cracked screen still does no turn on
- de
I'm assuming you made sure the battery was fully connected and charged?
- de
you would be assuming correctly :)
- de
Hello James, would you happen to still have one of these systems with you? I'm looking for a replacement part.
- de
no sorry no longer have it
- de
Agregar un comentario
1 Respuesta
Solución Elegida
People in this reddit thread claim that, similarly to 3DS, Switch's memory modules are not swappable. Apparently memory modules are locked behind device's unique key.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 694
