Saltar al contenido principal
Released May 2012, identified by model number J2011-03-US.
Preguntas 45 Ver todo
Charge port melted now wont charge
Started to smoke and melt while charging. Now when I plug in charger it doesn't show it is charging on the power button. Assume it isn't charging but haven't run battery all the way out yet.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
@smu89 if it truly melted you are having some major issues with it. Unlikely that it would charge nor would I try. Disassemble it by using this guide and see what damage you find. Post some images with your question so we can see what you see . Use this guide for that. Best case scenario you require only a new charging port, worst case you have some logicboard component failure.
Imagen de iFixit
Guía
Agregar imágenes a una pregunta existente
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Jawbone Big Jambox Charge Port
Guía
Jawbone Big Jambox Charge Port Replacement
Dificultad:
Moderado
20 - 30 minutes
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Jeff estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 711
