Saltar al contenido principal
Anunciado en Marzo de 2015, y lanzado al mercado el 10 de Abril de 2015, el Galaxy S6 es el nuevo buque insignia en la linea Galaxy. La version curva de su pantalla es conocida como Galaxy S6 Edge.
Preguntas 487 Ver todo
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
- de
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Reemplazar la batería del Samsung Galaxy S6
Samsung Galaxy S6 Daughterboard Replacement
Imagen de Samsung Galaxy S6 Batería
Guía
Dificultad:
Difícil
40 minutes - 1 hour
Imagen de Samsung Galaxy S6 Daughterboard
Guía
Dificultad:
Difícil
45 minutes - 2 hours
Fue útil esta respuesta?
Puntuación 0
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Puntuación 0
Añadir tu respuesta
Amy ford estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 136
