Internal Power Supply Replacement Issues
Hello,
i think this is going to be a bit hard to explain but i shall try!
so the Xbox i have, it doesn't turn on anymore. found the problem in the power supply. it obviously had some kind of component explode. big burn marks all through the power supply. i had another Xbox one s who's power supply was absolutely fine. turned on and all. out of curiosity i grabbed that one and put it in the Xbox that had the burnt out power supply. that didn't work. didn't turn on so figured the MB is stuffed. the weird thing is, when i put the power supply back in to the console i know works, that now no longer works!
anyone else experienced this? or has anyone successfully fixed this issue?
Also, before anyone mentions it, warranty or contacting MS is most certainly not a option.
thanks in advance!
Es esta una buena pregunta?
1 comentario
yes it seems that the MB has a short and has killed the PSU
- de Jordan Dann
