Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 672 Ver todo
Does Motherboard and screen link?
Recently I went to fix my iphone and the person told me could be my motherboard because it kept restarting on its on. Now they said motherboard has issue, but screw also got problem. They are not charging me my motherboard because under warranty, but they charge me for screen change which its functioning. Does both even link? I felt cheated.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Was the screen cracked? I assume you paid for a new screen replacement and now it's having issues?
If the motherboard is having issues I don't think they should charge you extra for the screen.
They should cover their own screw ups and it's their fault.
Who knows but maybe they knocked off small little components right above the battery connector and in result stops the phone from recognising the battery properly causing intermittent restarting for no apparent reason even on charge.
Or It could be long screw damage (damage to logic board circuit traces) from putting a longer screw than it should of for the metal plate for screen ribbon connectors that has the four screw holes (Two are on the board and those ones are prone to long screw damage).
What repair did you bring the phone in for? (Nearly forgot to ask that)
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Ber estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 40
