Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1366 Ver todo
Rear camera work only on timelapese, and Slow motion.
I've just got an iPhone 7 Plus from my customer as he report the rear camera is not working only black screen. After I test it It work only on right side camera so I check the left camera it's not working but flashlight is ok. First thing is do is reset all setting still not working. Second is restore it to IOS 10.3.2 still not working. I tried to replace another new camera already try 3 cameras still not working. Then I check components relate to left camera connector nothing is missing or not working still no clue. Then I replace U3001 still not working.
Can anyone help me to fix this problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
How did you checked both rear cams ?
- de
Agregar un comentario
3 Respuestas
I did a little looking around because I'm having the same issue. All of what I read leads me to believe that it is an Apple defect (manufacturing defect)
So I would tell them to take it back to them.
Fue útil esta respuesta?
Puntuación 0
You found the solution? Same problem here!
Puntuación 0
1 comentario:
i also had the same problem , heat the camera with hair dryer and the flex as well for around 20-30 seconds . it worked for me
- de
Puntuación 0
Añadir tu respuesta
Sengtay estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 6,679
