Washer has code ld and doesn't spin
Washer has code ld after rinse circle and it doesn't spin
Es esta una buena pregunta?
monicazd ld is "Long Drain" error which could be that you have a defective drain pump or something in the pump preventing it from draining. You could always try to unclog the pump. Here are some decent instructions:
Things You Will Need
Pliers
Bucket
Duct tape
5/16-inch nut driver
Needle-nose pliers
Unplug your Maytag Bravos washer from the electrical outlet.
Slide the washer forward to access the drain and water supply hoses. Turn off the Bravos’ water supply at the wall. Use pliers to turn the water supply hose connections at the back of washer counterclockwise to remove them from the appliance. Use a bucket to catch any water left in the hoses. Pull the drain hose from the appliance drain hose or utility sink.
Secure the washer lid to the cabinet with a piece of duct tape. Tilt the Bravos washer forward and let the front of the appliance rest on the floor so you can reach the drain and recirculation pumps.
Locate the drain pump on the top left side of the washtub and the recirculation pump on the top right of the tub. Short, elbow-shaped inlet hoses connect both pumps to the bottom of the washtub. Discharge hoses connect to the side of the pumps and run up the side of the washtub. Two hose clamps hold the inlet hoses to the washtub and to the pumps.
Use pliers to squeeze the ends of the inlet hose clamps closest to the pumps. Slide the clamps halfway up the inlet hoses. Squeeze the ends of the discharge hose clamps and slide them away from the pumps.
Find the three 5/16-inch hex head screws holding the drain and recirculation pumps to the bottom of the washtub. Use a 5/16-inch nut driver to remove the screws from the pumps.
Unsnap the wire covers from the ends of both pumps to reach the wire harnesses. Unplug the harnesses from the pumps.
Look inside the inlet opening on both pumps. Use needle-nose pliers to remove any cloth or debris clogging the pump inlets. Look inside the inlet hoses still connected to the underside of the washtub for any cloth or debris clogging the pump inlet hoses. Use the needle-nose pliers to remove debris from the inlet hoses.
Reconnect the pumps to the bottom of the washtub. Attach the inlet and outlet hoses to the pump. Slide the hose clamps back to their original positions. Plug the harnesses back into the pumps and snap close the wire covers.
Return the Maytag Bravos washer to its upright position. Reconnect the inlet hoses to the back of the appliances. Insert the drain hose into the drain pipe or reconnect it to the utility sink. Turn on the water supply, plug the appliance into the wall and push it back into its original location. from here
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 40
Todo El Tiempo: 3,977
