Cruise control don't work
Cruise control doesn't working. ECS dont work.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
@nune , Add more info. to your question year, make, model,engine, transmission and complete question so we here at ifixit can answer your question effectively. What have you tried or checked already.
por
the one i have is plug & play all i have do is plug every thing in and soldered one wire to Red Ignition wire. still don't work but I have green light when i push button to turn on.
por
Agregar un comentario
4 Respuestas
Respuesta Más Útil
@nune, Jose, I will post some more or less generic/common reasons for cruise control to not function: Info found from links below.
Bad Fuse: Like many electronically controlled systems in your car, the cruise control has a corresponding fuse which will blow to protect the system if it senses a short circuit. When the fuse of for the cruise control blows, the cruise control will stop working altogether.
Failing Brake Pedal Switch: The brake pedal switch turns on the vehicles brake lights when it senses that the brake pedal has been pressed. Because cruise control systems have been designed to disengage when the brake pedal is pressed, the cruise control is wired to the brake pedal switch. If the brake pedal switch fails, the car may think the brakes are engaged and not allow the cruise control system to turn on.
Failing Speed Sensor: A speed sensor has many purposes including indicating the speed of the vehicle, regulating flow of fuel and ignition timing, and operating the cruise control. If the speed sensor fails the cruise control may stop working. You may also notice that the speedometer has stopped working and the engine has more difficulty when idling.
Damaged Vacuum Actuator/Hoses/Cable: On older vehicles, cruise control speed is maintained using a vacuum actuator and a cable connected to the throttle. A vehicle’s cruise control may stop working if the vacuum actuator has stopped working or if there is damage to the vacuum hoses. The system may also fail if the cable linking the actuator to the throttle is broken.
Check the links below for more troubleshooting of cruise control. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.popularmechanics.com/cars/how...
https://www.yourmechanic.com/services/cr...
http://www.doityourself.com/stry/trouble...
Fue útil esta respuesta?
Calificación 2
Comentarios:
there got be be something else wrong
por
Check all your lights - if any of my brake light bulbs are blown, the cruise control won't engage. Weird but true.
Calificación 0
I installed some led's under my t32 xtrail 2016...as well as an led brake/ turn signal trunk strip...it was all fine since my last dealership service, i realised my cruise comtrol had stopped work...the lights were installed a few months ago an I had no issues...the only thing out of the way was a spring they had to replace behind the brake pedal...after they did that it stopped working...the dealership says I should uninstall all the after market lights because of circuit overload that may cause the cruise to control to stop...I need some help plz
Calificación 0
Comentarios:
I agree with them, not that it's an overload, rather an under load... the module thinks the bulbs are blown out because they're not drawing proper current. You may be able to add load resistors in parallel with the lamps to pull extra current through the circuit so they appear to be ok to the module.
por
i’m guessing that you have a blown globe in one of your lights. I’m also guessing that the lights and cruise and other dash controls are all linked to the one fuse, therefore when a light blows out it breaks the circuit and stops anything else on that relay from working…
Calificación 0
Añadir tu respuesta
Jose estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 12
Últimos 7 Días: 83
Últimos 30 Días: 452
Todo El Tiempo: 2,964
