Water not coming through
Everything works but water not coming through to grounds
Es esta una buena pregunta?
Christina Inglett, Machine may require cleaning/descaling pg.26/27 in manual(1st link below), could be a bent/collapsed hose inside machine, pump may require priming or pump may be failing, Below find trouble manual, shooting guide, disassembly guide. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.partsguru.com/user/Rio%20Vapo...
Fue útil esta respuesta?
Is water coming through the group head when the portafilter is not in place? If so, try switching to a coarser grind and see if you can get coffee to flow then. If that doesn't help then I'd make sure your coffee basket and group head screen aren't clogged, and if those are fine then you might have a failing pump.
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 3,452
