My camera won't turn on without an SD card in it
So I recently installed Magic Lantern to my Canon 60D. All is well until I encounter a few problems:
- My charged camera's battery won't turn on when I need to use it. Putting the battery on the charging cradle shows that the battery is flat and in need of recharging
- My camera cannot turn on after I remove and reinsert the memory card. Removing and Reinstalling the battery fix this problem
It all happened since I installed the Magic Lantern, so naturally I blame Magic Lantern and uninstall it from my camera. But even after I uninstall it, the problems still persist.
Recently I discovered that my camera won't turn on at all without a memory card inside it. Normally I can still turn it on at it showed "No Memory Card".
Anybody can help me?
Es esta una buena pregunta?
2 comentarios
I'm having the same issue Also. After installing magic lantern, the camera wont turn on with an SD card in it. If I remove the SD card and take the battery out then back in, the camera will turn on. But never when the card is in. Any ideas on how to fix this?
- de T0mbUs118
I am in exactly the same situation with the same symptoms but so far I have no idea of the cause and thus no remedy. Have you solved the problem since? how?
- de roze maussie
