Saltar al contenido principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Preguntas 355 Ver todo
My Samsung isn't charging.
Hello!
I got a pretty strange problem with my s7 edge for few days:
I am unable to charge it using my fast charger, because it can't be detected. I can charge it using an external battery though, which i charge with the same charger.
Any ideas about my issue?
P.S: my cable is a bit damaged but i think this might not be the problem as long as it does function on my external battery, right?
Es esta una buena pregunta?
Puntuación 5
3 comentarios
aka.aleex, Get your self a new compatible cable to eliminate that as a problem, especially if it is showing any sign of damage.
- de
but it is charging my battery, and i can charge the phone via pc aswel. at first, i thought it's a software error
- de
I want to gift my Samsung 7 but it's not charging!
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Make sure you use the original power adapter and USB cable because if not, that might be the reason why your phone isn’t charging at all. Remember, a battery as huge as the S7 Edge’s need a powerful charger and considering it’s capable of fast-charging, you need something that’s specifically designed for such feature.
Check both ends of the cable for corrosion, debris and/or lint. Anything that goes between the receptors in the phone and the pins in the cable may interfere with the normal charging process. Be also on the lookout for bent or crooked pins. If you can find one, try straightening it out.
Inspect the port on the power adapter. Try to see if there is corrosion of some kind or bent pins. You also need to check the USB or utility port on your phone for the same thing.
Assuming there is nothing that blocks or corrodes the pins, try turning off your phone and plug the charger in to see how the phone reacts. If it shows the usual charging symbol or lights up the LED indicator, then the charger is ok as well as the cable. However, if the phone doesn’t respond, then it might be an issue with the adapter or the cable and to rule out these possibilities, you need to use a different charger. If the phone charges fine with other chargers, then you need to buy a new charger kit, otherwise, continue troubleshooting.
If the phone won’t respond when plugged in, it might be a simple system crash issue.
Perform the forced reboot procedure by pressing and holding both the Volume Down and Power keys together for 7 to 10 seconds. The phone either reboots or the screen flickers for short time. You can then try charging your device and see if it responds this time.
Boot your phone in recovery mode if it still didn’t respond when you plugged it in. In Android System Recovery, all necessary hardware are powered up but the Android GUI isn’t loaded. So, if it’s not a hardware issue, your phone should be able to boot up in recovery mode: press and hold the Home, Volume Up and Power keys together.
If the phone won’t boot up in recovery, it’s time to have it replaced because it might be a hardware problem. However, if it started fine, then try wiping the cache partition. If that didn’t make any difference, then try doing the reset still through recovery mode. In case the phone remained off (and didn’t even flicker), there’s a chance the battery was all drained and since the device won’t charge, seek help from a technician.
Fue útil esta respuesta?
Puntuación 6
2 comentarios:
The cord works with charging up the fast charger, just not when hooked to the fast charger to charge the S7edge. Phone charged fine with auto charger and wall charger (not the Samsung one issued with phone.)
- de
i have a Samsung galaxy s7. and for a week now, i haven't been able to charge it using the original charger. or any other charger. It sometimes will charge a second. then stop. one time it said moisture has been detected. but i did not get it wet. And i haven't been able to charge it. how can i fix this?
- de
I think I have solved the charging problem with the Samsung s7. I would stop at 53% and go no father. I allow it to discharge to 0%. The I charged it again and this time it stopped at 73%. Then discharged it to 0% again. And recharged it again, and this time it went to 100%. It seems like that the battery need to be exercised up and down to get full activation of the cell in the battery. The old wet cell batteries would sulfate and act this same way.
(plates would become hard and not be able to accept the electrolyte).
Don't know if this is the case but it fixed my problem with the phone not being able to reach 100% charge.
Don R
Puntuación 3
Argmhgdfzgjjtusktudytskiyst
Update (12/12/2018)
87fyuyfuoydoudtcghiuitdcuygictyidgydtycfyidfyi87rtiglcgcj,
Puntuación -1
be a iphone user brother
Puntuación -1
Añadir tu respuesta
aka.aleex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 69
Todo El Tiempo: 83,970
