Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
iPhone 5s apple logo stuck
My iPhone 5s stuck on appl logo. When I connect to charger or laptop apple logo comes for two seconds and go off again and again. When I try to reset it with iTunes by pressing the home button and connect to laptop the iTunes connect logo appears on phone screen but it doesn't detect on my laptop. Please help me.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 15
1 comentario
My iPhone 5s stuck on appl logo. When I connect to charger or laptop apple logo comes for two seconds and go again stuck apple logo
- de
Agregar un comentario
7 Respuestas
Respuesta Más Útil
In order to get the iPhone out of the Apple logo loop, you can try DFU mode as below: Hold down the Home and Power buttons at the same time for 10 seconds. Then, release the Power button while holding the Home button for another 15 seconds.
Fue útil esta respuesta?
Puntuación 9
4 comentarios:
Make sure the phone is plugged in before you do this. I don't think DFU mode will boot without a charging cable plugged into the phone.
- de
Whats it meant to do after you done this progress
- de
Well, I tired this and my screen went black! Doesn't want to turn on. Do you think I need a new battery?
- de
I tried this but nothing happened, its still the same with Apple logo on black screen. What should I do next? Please help. Thank you.
- de
This is an issue I experienced when my iPhone 5S didn’t have a battery connected and tried to boot. How long did the battery last before this issue? Did it take a really long time to turn on plugged in? You can buy a battery here: iPhone 5s Battery the guide is here: Reemplazo de la batería del iPhone 5s Hope I helped!
Imagen de iPhone 5s Battery
Producto
iPhone 5s Battery
$29.99
Puntuación 0
2 comentarios:
Isnt it really hard to replace a battery in an iphone because they do not have removable backs though?
- de
@elenaquinn10 Well, not really hard, but it depends on the model, the pull and release adhesives used from iPhone 5S all the way to iPhone 8 make things relatively easy, it's not just like removing a back cover but with the right tools it just takes 15 mins..
- de
So, what could be the reason behind white Apple logo screen of death? Usually, iPhone gets stuck on the Apple logo screen when there’s a problem with the operating system that prevents the phone from booting up like normal. Below we list some of the most common reasons why iPhone or iPad frozen on Apple logo.
  1. iOS Update: iPhone had problems while upgrading to the latest iOS 13.
  2. Jailbreaking: iPhone or iPad stuck on Apple logo screen after Jailbreak.
  3. Restoring: iPhone frozen on Apple logo after restoring from iTunes or iCloud.
  4. Faulty Hardware: Something is wrong with the iPhone/iPad hardware.
How to fix ? You can refer to this article:https://www.fucosoft.com/iphone-issues/i...
Puntuación 0
I have an Iphone 5s that’s stuck in this loop, but at the same time the screen turns red. I already tried to reset it with the power and home button, but nothing happened.
Puntuación 0
1 comentario:
i did the same
- de
Iphone 5s logo blanking
Puntuación 0
iPhone 5s display blanking
Puntuación 0
Maybe a dead battery or a software issue. If these didn’t help it may be a hardware issue
Puntuación 0
1 comentario:
Could a dead battery cause the apple logo to stay eternally on the screen of the device (device is plugged on the charger)?
- de
Añadir tu respuesta
Iqbal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 28
Todo El Tiempo: 53,534
