Saltar al contenido principal
La Canon PowerShot SX160 IS es una cámara digital de 16,0 megapíxeles con un zoom de imagen óptico gran angular de 16x y una pantalla LCD de 3,0 pulgadas.
Preguntas 20 Ver todo
Display of message that says 'change the batteries'
My camera keeps displaying a message that says 'change the batteries'. Why is this?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
@tyiilliamani, Kenzo , Ensure that the battery contacts are clean and install a new quality set of fully charged batteries and if using rechargeable's have charger tested or try another known good working compatible charger to rule it out as an issue. Possible internal clock battery may be faulty (change internal CR1220 battery) or issue with bad components in camera. Find below links to showing the internal clock battery replacement and partial disassembly guide to enable checking of internal wire connections/components/etc. to check for loose, damage, burnt. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Canon PowerShot SX160 IS Clock Battery Replacement
Canon PowerShot SX160 IS Outer Case Replacement
Imagen de Canon PowerShot SX160 IS Clock Battery
Guía
Dificultad:
Moderado
15 - 30 minutes
Imagen de Canon PowerShot SX160 IS Outer Case
Guía
Dificultad:
Moderado
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Kenzo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 3,510
