@lynnehammer welcome to iFixit. Age and gender do not matter on iFixit Answers, what matters here is a great attitude ;-)
Your symptoms sound like issues with the PTO clutch or with the ignition module (it runs very rough for no more than 5 seconds and dies.) or possible a faulty safety switch. So here are a couple of basic things that you can test. Let us know what you find:
Perform these tests in a clear open area. Keep bystanders away.
Testing Park Brake Switch
1. Park machine safely. (See Parking Safely in the SAFETY section.)
2. Sit on seat.
3. Unlock the park brake.
4. Try to start engine.
Result: Engine must not crank. If engine cranks, there is a problem with your safety interlock circuit.
Testing Park Brake
2. Lock the park brake.
3. Try to push machine manually.
Result: Park brake must prevent machine from moving. If machine moves, parking brake needs to be adjusted.
Testing PTO Switch
2. Sit on seat.
3. Lock the park brake.
4. Engage the PTO switch.
5. Try to start engine.
Testing Seat Switch
Test 1
1. Start the engine.
2. Move throttle lever to maximum speed position.
5. Raise up off seat. Do not get off machine.
Result: Engine should begin to stop. PTO should shut off immediately and mower blades should stop.
Test 2
1. Disengage the PTO switch.
2. Start the engine.
4. Raise up off seat. Do not get off machine.
Result: Engine should stop. If engine does not stop, there is a problem with your safety interlock circuit.
Test 3
3. Raise up off seat. Do not get off machine.
Result: Engine should continue to run.
We may need the wiring diagram for further trouble shooting
BTW remember to engage the PTO at WOT (Wide Open throttle)only. It may be that the PTO bogs down the engine if less than full throttle.
8 comentarios
Why did you change it in the first place?
- de Cameron
The lower belt had slipped off and when I looked at it, both belts looked worn. The blades were pretty beat up too so I decided to tackle the whole shooting match.
- de Lynne Hammer
If you remove the belt to the blades and then engage then, does it still do this?
- de Cameron
I'll give that a shot tomorrow and let you know. Thank you for your comments. Really.
- de Lynne Hammer
No problem. Get back tomorrow. Also, if leaving a comment for me, out @cam2363 somewhere in the comment. That way you can ensure that i will see it.
- de Cameron
Mostrar 3 comentarios más
