Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Honda Accord de séptima generación, de 2003 a 2007.
Hot air blows thru drivers side and cold air on passenger side
2007 Honda Accord sedan air is hot on drivers side, cold on passenger side.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios:
is the driver temp dial hot and the passenger temp dial on cold?
- de
I have this problem too and the car does not have dual controls.
- de
I have this problem on my 2007 accord with dual control. I turn the driver side down to low which is as low at it can go and after one minute I turn it back up and seems to work find
- de
Agregar un comentario
4 Respuestas
Non dual control.
There is a cable fault or something has become detached or worn.
Dual control.
There will be a fault with the motor which drives the air direction flaps.
Both means that someone will have to pull apart some of the dash to get to these control areas.
Fue útil esta respuesta?
Puntuación 0
Here’s a couple of videos on how to fix it:
https://www.youtube.com/watch?v=w-NX26kn...
https://www.youtube.com/watch?v=q3h2DVYH...
https://www.youtube.com/watch?v=ddMrFiGj...
Puntuación 0
I have a 2004 Honda Accord Coupe EX my AC blows hot I put freon in it the compressor works fine everything is good but just does not blow cold what do I do
Puntuación 0
so what should i do I have a 2004 Honda Accord Coupe yes my AC does not blow cold and both hot it has freon compressor is fine everything is good don't know what to do
Puntuación 0
Añadir tu respuesta
Mercy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 2,051
