Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
The P9 Plus is the premium version of the Huawei P9 flagship smartphone. Features include a unibody case and dual rear-camera setup developed in partnership with Leica, 64 GB of internal memory expandable up to 1TB with a microSD card.
Preguntas 14 Ver todo
Not charging ( % drop while charging ) and not recognizing in PC
about after a month of using my P9+ the first thing started to happen is that over the time charging time with increasing and after a while it got even worth it would take about 12 hours to charge up the phone
so I have replaced the charger and the cable still not charging replaced it agin and still not charging and I bought it from abroad so the warranty is not valid her
did a factory reset and still not charging
and
I have just replaced the charging board and I thought that the problem was there but it is still not charging after all
I don't Know what to do
any help
please
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
2 Respuestas
Solución Elegida
Have you been using cheap car chargers? That may have contributed to the charging circuit getting damaged.
It's most likely an on logic board issue with charging ic chip getting damaged, once that stops working charging stops working completely and additionally probably detecting on computer too.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
no I have been using the original charger that came with the phone .
so is this IC On the main board can be replaced ?
- Por
It sure can be replaced but unfortunately it's near impossible to find someone that does it or has the part. The only way to get the part is to take it from another phone if it can't be found online. It requires someone that does micro soldering with a microscope and a soldering iron also a hot-air rework station.
Usually I would suggest you to take the phone back to Huawei for warranty replacement (contact them first via phone support before doing so) but since you have opened up the phone you have most likely voided the warranty sticker which is a white sticker on top of a screw (I've personally opened up my Huawei P9 without voiding warranty as the sticker is right on a screw for the battery connector cover on my one).
I mean the Huawei P9 / P9 plus was released on 29 April 2016 which means the device would of been in warranty still if you bought it on or after 4th of May 2016.
- Por
hi ben, i have send you an email regarding this problem. kinly check and we could discuss there.
Puntuación 0
Añadir tu respuesta
akram.elhayani estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 57
Todo El Tiempo: 1,953
