Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2686 Ver todo
iPhone 6s fingerprint problems
Hello guys,
i recently buyed a dozen of I6s and i6s + screens,
and i had a question about the fingerpringt,
i have 3 iphones (2 iphone 6s & 1 iphone 6s+)
they all have the same problem , i replaced all the iphone screens and1 of the 3 works.
i tried the button on all the screens that i have an none of them works i try to use the one that works on the screens and also they do not work, i replaced the button back to the one that worked and then it did not work anymore, i keep on trying and suddenly i manage to make it get back to work aggain so i leave that phone alone, but is there a way that i might have damaged it :s or an component. or are the screens all faulty?
because i never had so much trouble then with the iphone 6s its realy abnormal.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
What quality screens did you get? Issues with the Touch ID are very common with the aftermarket screens so if you are buying aftermarket then they are probably just faulty screens
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
What you mean by aftemarket
- de
copy screens using non OEM material
- de
How come some screens work then,
So copy screens will never work ?
- de
No some of them work just fine but a lot of them have issues with Touch ID, not all of them but a lot of them. I have had quite a few faulty copy i6s screen which would not work with the Touch ID but I have never had that issue with OEM screens.
- de
How you be so sure its oem quality since the flex cable can be coppied as wel, and recievd 1 screen today and its indeed the shield problem
- de
Añadir tu respuesta
glennjacobs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 191
