RCA Android tablet with detachable keyboard, identified by model number RCT6303W87DK.
Preguntas 336 Ver todo
I can't get my tablet to turn on
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
My tablet is not turning on
por
my tablet comes on to the android screen then turns off immediately
por
I pushed the reset button, that did not work. i won't come on took the battery out but still nothing
por
my laptop/tablet isn't working. the screen is black.
por
My charging light is flashing blue on my rca Viking pro 10 but won't turn on. Cant even hard reset it. Nothing is working. Any suggestion
por
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
With the charger connected does the tablet indicate that it is charging at all?
Try resetting the tablet by using a straightened out paperclip to press the reset button which is found on the back of the tablet. When you insert the paperclip into the reset hole you will feel a button being pushed. Hold the button down for about 4-5 seconds then release to turn the tablet on
Here is an image that shows where it is located.
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Calificación 3
Comentarios:
Hi @cam2363 ,
I think that you seem to be making a wrong assumption regarding your description of the device in your comment.
The manufacturer describes it as a "tablet", not a laptop, (ifixit also describes it as a tablet - see image and description linked to question), so the OP is also likely to describe it as such, because that is what it is known as, i.e. a "RCA 10 Viking Pro 2-in-1 tablet"
I'm being no more "picky" than you regarding this. ;-)
por
@jayeff Sorry, i didnt notice that
por
After resetting it only shows VIKING PRO what does it mean
por
Añadir tu respuesta
Serina Komlosky estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 18
Últimos 30 Días: 71
Todo El Tiempo: 809
