Can you fix lose hinges?
my hinges are lose. and i'm not sure if i can fix it myself or where i should send it to get fixed
Es esta una buena pregunta?
@snookiex628,beth, You are not the only one with this loose hinge issue, if still under warranty consider using the warranty for repair/replacement/refund. If not under warranty check the links below for a pretty much low/no cost fix and other info. Other wise you may end up having to replace the upper and lower case. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=lj0C4yyI...
Fue útil esta respuesta?
Ultimas 24 horas: 6
Ultimos 7 días: 39
Ultimos 30 días: 150
Todo El Tiempo: 16,666
1 comentario
You could try getting a replacement hinge and installing it, but that's pretty hard if you have never done a repair on a 3ds yet. If it's still playable just deal with it (my dual ips 3ds wobbles like crazy!) or if you can't stand it send it to nintendo
- de Leonhard Bokowski
