Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 1041 Ver todo
iPhone 6S Plus Main Camera, 3D touch and flash light Not working
I have an iPhone 6S Plus with some issues. Main Camera and 3D touch Not working at all, flash light Not Working too. I checked the motherboard and I see sigh of water damage but everything else works fine. Do I need to replace any IC to solve this issue? What parts do I need to inspect with the microscope and test? Maybe some parts (like Resistors, Capacitors or IC) burned. I would appreciate your help. Thank you!!!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Clean the board and replace any bad components.
Fue útil esta respuesta?
Puntuación 2
6 comentarios:
I cleaned the motherboard, how can I find the bad parts; I can't see any clear damage with the microscope. What parts needs to test with the multimeter; maybe a chip needs replacement or some resistors-capasitors-filters
- de
Are any components blackened/burnt?
- de
I don't see any black components near the main camera connector
- de
What about pins on the connector? Are those burnt a little?
- de
no, seems it is ok. I think the problem is on the camera chip.
- de
Mostrar 1 comentario más
Añadir tu respuesta
johnfl21 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 196
