Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 4053 Ver todo
iPhone 5s when plugged in screen flash logo then black
i got an iphone 5s, screen is black.
When plugged it in, the screen will flash logo once, then again black.
i removed the battery and plugged it in, same thing, one flash.
Any idea what could be the problem?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Does the backlight still stay off after the logo goes off?
- de
Nick, I think I know where you are getting at: Might be an iPhone 5s that is stuck in DFU recovery mode.
This is usually caused when the device is not turned off properly (Sometimes during repair). I fixed this by doing a restore, it had to be restored in my case. Try update first OP.
- de
backlight stay off, after the logo flash, i will try a dfu recovery/restore.
- de
Agregar un comentario
SALTEA LA ACTUALIZACIÓN
Ahorra reparando con un kit todo en uno.
Compra Kits de Reparación
1 Respuesta
Solución Elegida
It's either the battery, or you need to restore. Like the latter. Try this first
Plug your device into your computer with a USB cable.
Turn off the device.
Hold the Power button for 3 seconds.
Hold the Home and Power buttons for 10 seconds.
Release the Power button but keep holding the Home button.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
i did remove the battery and plugged it in, same flash, so, most likely not the battery. If i need to restore, it should give me the itunes logo.
- de
Using the same battery doesn't rule it out. Using a known good one will
- de
Also if you're gonna help out on here. Which I appreciate. You should make an @ tag in your profile. Like this @refectio you're awesome! Now he's gonna see that in his notifications and is gonna look here. It's a way we use to communicate here, in this sea of answers
- de
who...er, what...what's going on here...did someone call me? You're awesome too Mr. THEiMedic!
- de
@imedic about the battery, what i mean was that i disconnected the battery and plug in the charger, it gives me the same logo flash. but i will try a good battery.
- de
Mostrar 4 comentarios más
Añadir tu respuesta
cli168 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 3,209
