Saltar al contenido principal
The Microsoft Band 2 is a smartwatch, released in 2015 that syncs to your phone in order to track exercise and activities.
Preguntas 9 Ver todo
Buttons on the side do not work, Battery wont charge.
As it says. I had by band for about three months. Then at one point. It just went off, buttons unresponsive. I powered it on, Pressing any of the buttons did nothing and the battery wont charge at all. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Hi. If your band is only 3 month it should be on warranty so you could write to Microsoft and they would give you a replacement. But I suggest you to ask for a refund. I had the same issue 3 times in a year. Everytime they sent me a replacement but the device keep failing. Now the warranty run out and the devices is broken again. I contacted them and they couldn't give me a soulution
Fue útil esta respuesta?
Puntuación 1
Had the same problem with my Band 2 today.
Everytime I plugged it in, it started for a few seconds and I could use the touchscreen (not the buttons, though, as in your case). So I navigated to the cogwheel symbol then to the power down function and there I chose to factory reset it.
Now at least it says that it's loading while being plugged in (the white loading symbol shows on the black screen). I hope that fixed it. You might give it a try if you have the option to use the screen for a few seconds, like I could.
EDIT: Didn't fix it. It says that it's loading now - but it isn't. :|
Puntuación 0
my Problem:
batterie forgotten to load and was empty, only display worked
my workaround:
- load Band2 for min. 24 hours
- reset Band2 to factory settings over display
- unconnect from Microsoft Band software -> phone
- deinstall Microsoft Band software
- 2nd reset Band 2 to factory settings and load for min 24 hours
After this I can use it as a new device and my Band works now for more than 2 month
Puntuación 0
I just had this problem and my band was outside of warranty so thought I'd try and sort it myself.
I just took the battery out and then put it back in and my band seems to work again now. Both buttons and battery.
Worth a try as it only takes about 5 minutes
Puntuación 0
Hi! (Sorry for my english)
I had the same issue. I got it brand new (my wife’s gift) I remember that I charged my MS Band2 before batery run out… then the first time I forgot to charge it, it shut off, charged it, turned on, set date, and when I unplugged it, instantly turned off and didn’t turned on again when pressing the buttons. Then I connected the cable to my band and only appeared the black screen with batery icon and a little bar blinking at the corner of the screen. Never came back to set up screen.
Let it unplugged for five months and I charged again (now the battery was completely empty) and a few hours later (almost 12 hours) the band came back to life again. Set it up, weared it, didn’t let the batery go empty, but after one week I forgot to charged it again and the band shut off. Charged it, display turned on, set it up, but this time when I unplugged it the band shut off, like if the batery was empty. I get it plugged and try to factory reset it, but the device didn’t let me do that. So I gave up for at least 1 year and then I gave it a try once again. This time I was unable to get it turned on, the same batery icon and blinking bar in black screen. I let it connected almost 3 days and at last, the band came back to life (the day I’m posting this answer). This time I couldn’t set it up just the band alone, it asked me to pair it to my phone to complete the configuration process. So I did it, and everything went okay. Then I took the advice of you people and factory reset it, set it up, but before app-band configuration process, I ereased in the Microsoft app all the data and the previous MS Band2 device that was saved previously. So It detected a new device and finished the configuration. Now my band appeared to be okay. I’ll let you know how it worked in a few days.
Puntuación 0
Añadir tu respuesta
Joseph Case estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 1,078
