Saltar al contenido principal
Tableta Surface Pro de tercera generación, lanzada el 20 de junio de 2014.
Preguntas 123 Ver todo
Dead, opened up the case, now what?
Surface Pro 3 would not start up.
Tried all the usual button press combinations and even putting it in the freezer. I did notice the charger LED would sometimes blink whilst holding down the buttons, but nothing on the screen.
I suspected the battery, so pulled off the screen with the aid of a heatgun. Unfortunately it reads 8 Volts (versus spec on the label of 7.6V). Label also says the battery is 20 months old.
Is there anything else I can try ?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
You have it open I would replace the battery. On some tablet the simple act of disconnecting the battery and reconnecting it is enough to restore the tablet . I have however never heard of this working on a surface but Id give it a try
Fue útil esta respuesta?
Puntuación 3
1 comentario:
I have disconnected the battery, did not make a difference. I will conside replacing the battery, unfortunately it is glued in place.
- de
Is this yours or a customer's. Sometimes this is caused by the CPU overheating on the surface. Because a client had left theirs on during a windows update in a bag and it overheated and never turned on again just turn on no display, post or input.
If data is needed from it you can use a mSata adapter to plug into a desktop computer and hope that it's not bitlocker encrypted.
Puntuación 2
3 comentarios:
Its mine. I don't get POST and cannot hear the fan spinning up. I had a previous Surface 3 pro go dead but replaced under warranty. This one went to sleep while connected to the charger and never came back. It has bitlocker, but I store all my data on my network anyway. Just trying to get more life out of it. I recently bought my daughter a Surface Pro 4, hopefully it will be more reliable, otherwise we will need to revert to regular laptops.
- de
I'm guessing you have tried holding volume down and power button to force reset shut off it right?
- de
Yes I have tried all the different key press combinations. Look like I will need to try and source a second hand motherboard.
- de
Añadir tu respuesta
adornan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 268
