broken sd slot needs replaced on my T100
how do I replace the broken microsSD slot?
Es esta una buena pregunta?
thelacys, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a couple links to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Asus Transformer T100 Motherboard Replacement
https://www.youtube.com/watch?v=RM_fIU_B...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 189
2 comentarios
Thank you so much!
- de thelacys
thelacys , you are welcome, thanks for replying back. Good luck with T100.
- de L Pfaff
