Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Mavic Pro es un dron plegable y compacto con capacidades de video 4K, lanzado por primera vez en noviembre de 2016. El número de modelo es M1P y su modelo de controlador es GL200A.
Why does my drone get a Jello-effect?
Why does my drone get a Jello-effect ?
I have tried to utdate everything, but nothing seems to make it better.
Blury picture on the phone while filming..
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
That must be from vibration. Most drones that don't have a damper have this problem, but that shouldn't happen with this one. If your under warranty, send it in to DJI so they can have a look at it.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
@pccheese ,Cepeders, Blurry picture on the phone while filming, try a different device as maybe your phone is not linking properly. If under warranty consider using it for replacement/refund/repair. Check to see if the camera/lens is loose on the drone and vibrating around. You may have already done so, do a search( dji mavic pro drone blurry picture) as there is numerous post/articles/forums that discuss this issue. Find below a disassembly guide to get you inside the check for loose wires/components/etc. that could cause an issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Desmontaje del DJI Mavic Pro
Puntuación 2
Añadir tu respuesta
Cepeders estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 2,048
